johnjoejohn
Junior Member level 2
Is there a 1 hole connection part in eagle? Im not looking for a mounting hole. I am making a pcb where a big wire will need to be solder onto the board, and this wire is connected to a pin (mosfet). Basically I am looking for a 1 position terminal block but the hole will have to be big like mounting holes because I need to connect like a 10-12 gauge wire directly on it. This is because It draws a lot of current (30+Amps) and most connector will melt.
