e-shape microstrip antenna
smritigupta
Newbie level 2
Newbie level 2
jhansi
i am doing my final year project on e-shape microstrip antenna.please help me out with the design equations and programming tools in matlab for the vswr, return loss and radiation pattern curves.
You might also want to try simulation using HFSS, CST, FEKO etc ...
yups i am doing simulation using ie3s software but all the design equations are not with me.help me with the designing equations for antenna
I fooled with one that I found described in the ieee antenna proceedings several years ago. I don't recall the author but I have periodically seen similar references. You mingt see what you can run down of recent vintage. As I recall it was in the vicinity of 2 GHz and I came up with around 25% vswr (-10dB) bandwidth and gain on the order of 4-5 dBi.
I did not use closed form equations but rather modeled it parametrically using HFSS and tuned it from there.
microstrip antenna mathmatics is well developed and there r lots of research papers and books on this topic....and one very good book on this topic is written by Prof. Ramesh Garg IIT Kharagpur.......so u hv gone thru this topic and see some gud work done by Prof. B R vishwakarma Group..u can refer his papers for doing ur project............................here i am attaching one paper on E shape microstrip antenna for wideband application.............i think it will help uuuuuuuuuuuuu
  • a_wideband_e-shaped_microstrip_patch_1657.pdf
