DVP12SA211T
shahbiud
Newbie
Newbie level 1
DVP12SA211T
Has 8 digital inputs including:
3 high speed inputs 100KHZ
5 10KHZ average speed inputs
Has 4 digital outputs including:
2 high speed output 100KHZ
2 10KHZ average speed output
16KSTEP programming capacity
Upgradable input / output
DVP-SA2 series has two models, both models have 8 inputs. The main difference between these two models is in the type and number of outputs, so that the DVP12SA211R model has a relay output, but the DVP12SA211T model has a transistor output.
The 2nd generation slim DVP-SA2 series PLC offers greater programming capacity, optimal execution, high-speed output of 100 kHz and counting functions. It can also be upgraded with left and right DVP-S series development modules.
The second generation of advanced slim type PLC
Advanced PLC with the ability to support left high speed modules
32 bit CPU
Programming capacity: 16K STEP
10K word data storage
Execution speed:
LD: 0.35 .s
MOV: 3.4 .s
It has one RS232 port and two RS485 ports
Supports standard MODBUS ASCII / RTU protocol and plc communication functions
No battery required, uninterrupted timer operation 15 days after power failure
Supports DVP-s series right and left modules
