macadam
Hello,
I have developped a satellite receiver using STI5518 and the datasheets I found with the help of this forum. All work fine.
I now have to add a common interface to this receiver and plane to use the parallel interface present in the Front End Interface. Unfortunatly, it doesn't seem to work : PARA_REQ stays always inactive.
Did anybody already work on DVB-CI with STI-5518 and can help me.
Moreover I would appreciate if someone could tell me the order code for the STI5518 including the DVB-CI option (in case I can't find the solution to my problem using generic parallel input)
Many thanks in advance.
