Quickdraw1
Newbie
Hello,
I have switching noise on a test bench that I've been using for a while now. This test bench is used to test prototype PMSM machines designed to reach high speed levels (70000 RPM). We're planning on mechanically coupling two machines front to front (one as a motor and one as a generator) to increase the mechanical power.
For that, I have two inverters, one for the motor machine and one for the generator machine (so one will act like a standard inverter and the other one will act like a rectifier). Of course, there is a power supply to "beat" the system losses otherwise the whole thing would not work.
Here is the datasheet for the inverter (can't find the URL so I have to post a picture) :
The 3 half-bridges used are SKM350MB120SCH17, which are SiC MOSFETs.
Here's the problem : we using a 750 VDC bus to power the inverter, and those MOSFETs are quite fast, so the encoder that is used for FOC control of the motor often fails because of the dV/dt noise injected by the switching.
Because this is already a long post, I'll leave it here for now but if anyone is interested I can go in further details. Let me know.
