qqpost
Member level 1
Hi everyone,
I'm trying to use the mirror function to duplicate the elements. As it writes in the Help: 'Mirror an object about a plane. The plane is selected by defining a point on the plane and a normal point. ' But I'm not quite clear with the Base Position and Normal Position. How they work?
I tried different value of the Normal Position and the result changed. Can you explain why they look like this and what's the understanding of the base position and normal position? Thank you.
