Chachito,
How does the E-field vector affect the antenna parameters which we use for source excitation?
We use gap_src for all dipole design. If I increase gap_src, then the accepted and radiated power also increases.
How are these related?
Pls explain.
PS: I have attached antenna parameters when the gap_src is increased to 4mm.I have attached Z and S parameters too.
If gap_src is 2mm, then the accepted and radiated power are 0.3 W and when gap_src is increased to 4mm, the accepted and radiated power is as in attached file.
How should I select the gap_src value w.r.t the dipole length?
Thanks!
