Dual vs Triple synchronizer on FPGA input
shaiko
Advanced Member level 5
When is it worthwhile considering Triple DFF synchronizers on FPGA inputs instead of the commonly used Dual DFF ?
Reactions: shaiko
    shaiko
Dual will always give you a 1 or a 0. I only use triple when I need to do edge detection, or data alignment.
Reactions: shaiko
    shaiko
What if the metastability isn't settled for a full clock T and proceeds to the second DFF ?
From my understanding, the only problem is the first FF sampling during a transition of the IP, and it can go metastable. The 2nd FF should never sample an edge, so will always flip to 0 or 1, even if the first FF is metastable.
You assume that the metastability condition is resolved befor the second clock edge arrives. But what if we are working at a very high frequency and the metastability condition doesn't have enough time to resolve - causing setup time violations?
It is not possible to guarantee that metastability problems are avoided.
The MTBF for a circuit can be calculated, and you add synchronizer stages if you want to increase it.
From Altera handbook 12.1, Volume 1, chapter 14:
"Designers commonly use two registers in a synchronization chain to minimize the
occurrence of metastable events, and a standard of three registers provides better
metastability protection. However, synchronization chains with two or even three
registers may not be enough to produce a high enough MTBF when the design runs at
high clock and data frequencies."
