HighTechPower
Member level 5
Hi guys. I'm designing a +80V & -80V dual polarity SMPS with current sense resistors on high sides. The simulation file is doing perfect and figure is attached herewith. I followed application note (slup114) that I used to design current control loops as shown on it's page 22/23. However when checked on vero board, -ve rail current control loop output from U2 output is showing some negative voltages instead of +ve which I was expecting as done in simulation. Why is it so? What if I want it's output also some +ve value to trigger some circuit? Also to mention that reference voltage 1.24V is not showing on non-inverting pins of U1 & U2 when opamp IC MC34074 (LT1014 is used only for simulations and I actually used MC34074 on vero baord) is removed from socket and voltages checked. Maybe due to large 1Meg resistors R17 & R6 it's not showing 1.24V? What if I want 1.24V on non-inverting pins of U1 & U2 as well?
Also is there any better way to design dual polarity current s and voltage control loops? I tried to implement this way because I needed constant voltage and constant current triggering circuirty in action using single optocoupler by using ORing diodes at outputs of U1, U2 & U4.
