Jun 8, 2010 #1 D dss91 Junior Member level 2 Joined Jun 2, 2010 Messages 21 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,283 Location kmm Activity points 1,427 hai here i have a peculiar problem i have taken the dtmf output form mobile(nokia 2626) what will be the voltage of the dtmf signal??? i hav kept a voltmeter at the mobile jack to measure the output voltage from jack it reads zero????? ok leave that ihav two wires from the head set one is a red one and other black one how should i connect them this is my first doubt i hav connected the red wire from headset to pin2 and black to ground and i hav dialed it and checked the pin stD for a logic high and i got nothing even at the output pins i havnt got nothing i hav attached my circuit verify it
Jun 8, 2010 #2 jacob_abraham Newbie level 6 Joined May 26, 2010 Messages 11 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,283 Location Syria Activity points 1,350 problem with dtmf well. try to change gain of preamplifier resistors of 100K because gain in your circuit=1 so the voltage of dtmf signal must be bigger enough to tigger the MT for example try 1M by 10K
Jun 9, 2010 #3 D dss91 Junior Member level 2 Joined Jun 2, 2010 Messages 21 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,283 Location kmm Activity points 1,427 Re: is it 8870 or the jack teasing me help me plzzzz sorry i havnt got your point do you want me to change the resistor next to capacitor by greater than 100k ,i think that would certainly stop the dtmf or the resistor to pin3 plz suggest me in detail
Jun 10, 2010 #4 jacob_abraham Newbie level 6 Joined May 26, 2010 Messages 11 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,283 Location Syria Activity points 1,350 mt8870 basic application look at the schematic .. maybe it helps u.
Jun 10, 2010 #5 D dss91 Junior Member level 2 Joined Jun 2, 2010 Messages 21 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,283 Location kmm Activity points 1,427 Re: is it 8870 or the jack teasing me help me plzzzz i got your point ok i l try that thanks for your help
Oct 12, 2010 #6 S sreein Junior Member level 1 Joined Oct 11, 2010 Messages 15 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,283 Location india Activity points 1,394 Re: is it 8870 or the jack teasing me help me plzzzz is it work
