raman00084
Full Member level 6
in dspic33ep512mu810 i want to know what is the minimum voltage that the io can read as low ( VINL)
and what is the minimum voltage that the io can read as high ( VINH)
in data sheet i cannot see this clearly kindly help.
in my board i am using optocoupler pc 817, the voltage on the io pin is pulled up with 3.3v if the optocoupler is on the voltage drops to 0.4v and my
micro controller io reads as low. but i want to know the voltage range for VINL 0-?.
