Looks like the code is not open-source.Hi please some one kindly send me Hex file for dsPIC30F2010 Inverter with LM324 & LM393
What faults ?The LM324 measurement circuit has faults.
Unlikely. Looks to me like failed differential amplifiers. Otherwise the matched resistor chains are useless.The LM324 2.5V reference buffer has - and + inputs swapped.
You using these as comparators ? If so should have some hysterisis implemented
in them using + fdbk
Fault: e.g. the difference between post #1 and your schematic. Do you think they are the same?What faults?
some of latest desgins uses same techniques
Not open source fileHi please some one kindly send me Hex file for dsPIC30F2010 Inverter with LM324 & LM393
