dsPIC microcontroler Output compare module to PPS selection Query ?
thannara123
Advanced Member level 5
Hello ,
I am reffering some code from online written by Tahamid as follows
const int sin_table[512] = { 0, 5, 10, 15, 20, 25, 29, 34, 39, 44, 49, 54, 59, 64, 68, 73, 78,
83, 88, 92, 97, 102, 107, 111, 116, 121, 125, 130, 135, 139, 144, 149, 153, 158, 162, 167, 171,
175, 180, 184, 189, 193, 197, 201, 206, 210, 214, 218, 222, 226, 230, 234, 238, 242, 246, 250,
254, 258, 261, 265, 269, 272, 276, 279, 283, 286, 290, 293, 296, 300, 303, 306, 309, 312, 315,
318, 321, 324, 327, 330, 333, 335, 338, 341, 343, 346, 348, 350, 353, 355, 357, 359, 362, 364,
366, 368, 370, 371, 373, 375, 377, 378, 380, 381, 383, 384, 386, 387, 388, 389, 390, 391, 392,
393, 394, 395, 396, 396, 397, 398, 398, 399, 399, 399, 400, 400, 400, 400, 400, 400, 400, 400,
400, 399, 399, 399, 398, 398, 397, 396, 396, 395, 394, 393, 392, 391, 390, 389, 388, 387, 386,
384, 383, 381, 380, 378, 377, 375, 373, 371, 370, 368, 366, 364, 362, 359, 357, 355, 353, 350,
348, 346, 343, 341, 338, 335, 333, 330, 327, 324, 321, 318, 315, 312, 309, 306, 303, 300, 296,
293, 290, 286, 283, 279, 276, 272, 269, 265, 261, 258, 254, 250, 246, 242, 238, 234, 230, 226,
222, 218, 214, 210, 206, 201, 197, 193, 189, 184, 180, 175, 171, 167, 162, 158, 153, 149, 144,
139, 135, 130, 125, 121, 116, 111, 107, 102, 97, 92, 88, 83, 78, 73, 68, 64, 59, 54, 49, 44, 39,
34, 29, 25, 20, 15, 10, 5, 0, 5, 10, 15, 20, 25, 29, 34, 39, 44, 49, 54, 59, 64, 68, 73, 78, 83,
88, 92, 97, 102, 107, 111, 116, 121, 125, 130, 135, 139, 144, 149, 153, 158, 162, 167, 171, 175,
180, 184, 189, 193, 197, 201, 206, 210, 214, 218, 222, 226, 230, 234, 238, 242, 246, 250, 254,
258, 261, 265, 269, 272, 276, 279, 283, 286, 290, 293, 296, 300, 303, 306, 309, 312, 315, 318,
321, 324, 327, 330, 333, 335, 338, 341, 343, 346, 348, 350, 353, 355, 357, 359, 362, 364, 366,
368, 370, 371, 373, 375, 377, 378, 380, 381, 383, 384, 386, 387, 388, 389, 390, 391, 392, 393,
394, 395, 396, 396, 397, 398, 398, 399, 399, 399, 400, 400, 400, 400, 400, 400, 400, 400, 400,
399, 399, 399, 398, 398, 397, 396, 396, 395, 394, 393, 392, 391, 390, 389, 388, 387, 386, 384,
383, 381, 380, 378, 377, 375, 373, 371, 370, 368, 366, 364, 362, 359, 357, 355, 353, 350, 348,
346, 343, 341, 338, 335, 333, 330, 327, 324, 321, 318, 315, 312, 309, 306, 303, 300, 296, 293,
290, 286, 283, 279, 276, 272, 269, 265, 261, 258, 254, 250, 246, 242, 238, 234, 230, 226, 222,
218, 214, 210, 206, 201, 197, 193, 189, 184, 180, 175, 171, 167, 162, 158, 153, 149, 144, 139,
135, 130, 125, 121, 116, 111, 107, 102, 97, 92, 88, 83, 78, 73, 68, 64, 59, 54, 49, 44, 39, 34,
29, 25, 20, 15, 10, 5 };
sbit MOSA at LATB2_bit;
sbit MOSC at LATB3_bit;
//D at LATB0_bit;
//B at LATB1_bit;
unsigned int Result;
int PWM_Scaling = 399; //25kHz
int Frequency = 131; //50Hz
unsigned int Phase;
int TBL_ID;
void T2Int() org 0x0022{ //Timer 2 overflow interrupt
Phase = Phase + Frequency;
Result = Phase >> 7;
TBL_ID = sin_table[Result];
if (Result < 256){    //A and D on
OC2RS = 0;
MOSC = 0;
OC1RS = TBL_ID;
MOSA = 1;
} else{ //B and C on
OC1RS = 0;
MOSA = 0;
OC2RS = TBL_ID;
MOSC = 1;
T2IF_bit = 0;
} void main()
LATB = 0;
TRISB = 0; //All PORTB output
ADPCFG = 0x3F; //All digital
PR2 = PWM_Scaling; //Set Frequency by setting Period Register //PR2 since I'll be using Timer 2
OC1CON = 0; //Disable compare module
OC1R = 0; //Initial duty cycle = 0
OC1RS = 0;
OC1CON = 0x0006; //Keep running in idle mode, Time base is TMR2,
                 //PWM mode with fault pin disabled
OC2CON = 0;
OC2R = 0; //Initial duty cycle = 0
OC2RS = 0;
OC2CON = 0x0006;
[COLOR=rgb(226, 80, 65)]RPOR0 = 0x1213; //RP0 - OC1, RP1 - OC2       // why this two  maped RP0,RP1 ,Not RP2,and RP3 ?[/COLOR]
SR = 0; //CPU priority interrupt level 0
T2IF_bit = 0; //Clear TMR2 interrupt flag
T2IP_2_bit = 1;
T2IP_1_bit = 1;
T2IP_0_bit = 1; //TMR2 interrupt priority 7
T2IE_bit = 1; //Enable TMR2 interrupt
T2CON = 0x8000; //TMR2 on, prescaler 1
while (1){ //Infinite loop – Nothing to do now
} //End of code
This is the code for generating sinewave to drive H bridge
please see the circuit .
My question is the asked is written as comment in the above code which is in red colour.
In this piece code the RP0 and RP1 is mapped to OC1 and OC2 ,why dont maped RP2 and RP3 ?
NB : The new templete of edaboard is too much struggle to write a thread .Old was very simple ,I am disappointed .
