dsPIC controller for proteus simulator
ismu
Full Member level 2
Full Member level 2
nil
Any body know which simulator i can use for dsPIC30F2010 ,
you can use MPSIM in MPLAB. Select Debugger > Select Tool > MPSIM. You can run the program by giving initial condition from Debugger > Stimulus > New Workbook. Get a MPSIM tutorial from Microchip web. Enjoy!
Reactions: ismu
    ismu
Can i interface LCD display by using this simulator?
hi,
same problem having for me also
do you found out the solution for the simulator?
im using the Proteus simulator, for my controller also no more simulator is available.
kindly tell me do you got the solution for your controller?
thanks,
anboli.c
no i didnt get till now , how can you use proteus , which have only dspic33f series
i cant use the proteus, yeah its having only dspic33f only,
im also struggling in the simulator..
im still searching the way for the simulator. i cant get it.
There is no such virtual/visual simulator for dspic33f higher end devices. Proteus has supported a few dspic33f chips. For simulation you have to play with MPLAB sim. To start of working wit it this blog will help you.
HTML:
http://embeddedinterconnects.blogspot.com
enjoy!
