dspic 33ep512mu814 float is getting -.01 reduced
raman00084
Full Member level 6
Full Member level 6
fstr="100.12";
fvalue = atof(fstr);
lcd_gotoxy(1, 2);
printf(lcd_putc, "fstr: %s", fstr); the value pinted is 100.12
lcd_gotoxy(1, 3);
printf(lcd_putc, "fvalue: %f", fvalue); the value printed is 100.11
0.01 is minis ed if i use atof function this is constant for all values i checked for 10 different values the result is same 0.01 is getting reduced
kindly help
kalyan
Maybe you need some rounding function.
I'm jus guessing...
Because even a float has limited resolution, it can be that "100.12" is safed as "100.119",
Then if only the last digit is truncated the result is "100.11".
Could this be?
Klaus
Presume that printf("%f", ) rounds the float value towards zero instead towards the nearest decimal value. To correct the rounding behaviour, you'll need to add a sign dependant offset.
There's an option in ANSI C to select the rounding behviour with a float.h defined constant, but it isn't implemented in many embedded C compilers.
