SharpWeapon
Member level 5
Hello,
I am using DSP48E1 slice as a multiplier and it works fine. First I made a small design which has few modules inside, including a module which uses this slice and worked fine. Then I made a top level design where I joined many modules including the small design module, which uses this slice inside and when I tried to simulate the top level, I don't have output from the slice(It is just zero), all the inputs from the other module are perfectly getting to the input port of the slice but it gave a result of all zero. It still works with the small design module, I tried with first, alone. Anyone encountered such a problem?
Thanks!
Thanks!
