nirob220
Newbie
Hello
DS18B20 Program code worked but i want to add code fan control. if temperature 40.6 C over Fan on and if 40.6C under temperature Fan off..
Any one can help this program code. i already try but not work.... anyone help me..
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 const unsigned short TEMP_RESOLUTION = 9; const int RES_FACTOR_1[4] = {5000, 2500, 1250, 625}; const unsigned int RES_FACTOR_2[4] = {0x0001, 0x0003, 0x0007, 0x000F}; const unsigned int RES_FACTOR_3[4] = {0x8000, 0xC000, 0xE000, 0xF000}; unsigned temp; unsigned short j, RES_SHIFT; void Display_Temperature(unsigned int temp) { const unsigned short RES_SHIFT = TEMP_RESOLUTION - 8; unsigned int temp_whole, temp_fraction; unsigned short i; char text[8]; // Isolate the fraction and make it a 4-digit decimal integer (for display) temp_fraction = temp & RES_FACTOR_2[RES_SHIFT - 1]; temp_fraction = temp_fraction * RES_FACTOR_1[RES_SHIFT - 1]; //portc = temp_fraction; // Handle the whole part of temperature value temp_whole = temp; // Is temperature negative? if ((temp_whole & 0x8000) != 0u) i = 1; // Yes, i = 1 else i = 0; // No, i = 0 PORTC = i; // Remove the fractional part temp_whole >>= RES_SHIFT; // Correct the sign if necessary if (i) temp_whole |= RES_FACTOR_3[RES_SHIFT - 1]; //portd = temp_whole; IntToStr(temp_whole, text); // Convert whole part to string LCD_Out(2, 6, text); // Print whole part on LCD LCD_Chr_CP('.'); // Print dot to separate fractional part IntToStr(temp_fraction, text); // Convert fractional part to string // Add leading zeroes (we display 4 digits fractional part) if (temp_fraction < 1000u) LCD_Chr_CP('0'); if (temp_fraction < 100u) LCD_Chr_CP('0'); if (temp_fraction < 10u) LCD_Chr_CP('0'); LCD_Out_CP(text); // Print fractional part on LCD LCD_Chr_CP(223); // Print degree character LCD_Chr_CP('C'); // Print 'C' for Centigrades }//~ void main() { ADCON1 = 0xFF; // Configure RA5 pin as digital I/O PORTE = 0xFF; TRISE = 0x0F; // PORTE is input PORTB = 0; TRISB = 0; // PORTB is output // Initialize LCD on PORTB and prepare for output LCD_Init(&PORTB); LCD_Cmd(LCD_CURSOR_OFF); LCD_Out(1, 1, " Temperature: "); do { // main loop OW_Reset(&PORTE,2); // Onewire reset signal OW_Write(&PORTE,2,0xCC); // Issue command SKIP_ROM OW_Write(&PORTE,2,0x44); // Issue command CONVERT_T Delay_us(120); OW_Reset(&PORTE,2); OW_Write(&PORTE,2,0xCC); // Issue command SKIP_ROM OW_Write(&PORTE,2,0xBE); // Issue command READ_SCRATCHPAD Delay_ms(400); j = OW_Read(&PORTE,2); // Get temperature LSB temp = OW_Read(&PORTE,2); // Get temperature MSB temp <<= 8; temp += j; // Form the result Display_Temperature(temp); // Format and display result on LCD Delay_ms(500); } while (1); }//~!
