ds1820-examples for c51 needed !
onde
Junior Member level 1
ds1820 c51
Hello,
does anybody know a link or have same examples of programming the ds1820 in c51 ???
thanks in advance,
onde
f*p://f*p.wickenhaeuser.de/source/ds1820uc.zip
//DS1820 C51
//sbit DQ = p2^1;
typedef unsigned char byte;
typedef unsigned int word;
void delay(word useconds)
for(;useconds>0;useconds--);
byte ow_reset(void)
byte presence;
DQ = 0; //pull DQ line low
delay(29); // leave it low for 480us
DQ = 1; // allow line to return high
delay(3); // wait for presence
presence = DQ; // get presence signal
delay(25); // wait for end of timeslot
return(presence); // presence signal returned
} // 0=presence, 1 = no part
byte read_byte(void)
byte i;
byte value = 0;
for (i=8;i>0;i--)
value>>=1;
DQ = 0; // pull DQ low to start timeslot
DQ = 1; // then return high
delay(1); //for (i=0; i<3; i++);
if(DQ)value|=0x80;
delay(6); // wait for rest of timeslot
return(value);
void write_byte(char val)
byte i;
for (i=8; i>0; i--) // writes byte, one bit at a time
DQ = val&0x01;
delay(5); // hold value for remainder of timeslot
DQ = 1;
val=val/2;
delay(5);
char Read_Temperature(void)
union{
byte c[2];
int x;
}temp;
ow_reset();
write_byte(0xCC); // Skip ROM
write_byte(0xBE); // Read Scratch Pad
temp.c[1]=read_byte();
temp.c[0]=read_byte();
ow_reset();
write_byte(0xCC); //Skip ROM
write_byte(0x44); // Start Conversion
return temp.x/2;
