sagar2993
Newbie level 3
controllerIC16F690
RTCS1307
It is working fine for Proteus but it dose not work for my actual hardware please advice
please check my code
RTCS1307
#include <xc.h>
#include "lcd.h"
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
// CONFIG
#pragma config FOSC = INTRCIO // Oscillator Selection bits (INTOSCIO oscillator: I/O function on RA4/OSC2/CLKOUT pin, I/O function on RA5/OSC1/CLKIN)
#pragma config WDTE = OFF // Watchdog Timer Enable bit (WDT disabled and can be enabled by SWDTEN bit of the WDTCON register)
#pragma config PWRTE = OFF // Power-up Timer Enable bit (PWRT disabled)
#pragma config MCLRE = OFF // MCLR Pin Function Select bit (MCLR pin function is digital input, MCLR internally tied to VDD)
#pragma config CP = OFF // Code Protection bit (Program memory code protection is disabled)
#pragma config CPD = OFF // Data Code Protection bit (Data memory code protection is disabled)
#pragma config BOREN = ON // Brown-out Reset Selection bits (BOR enabled)
#pragma config IESO = ON // Internal External Switchover bit (Internal External Switchover mode is enabled)
#pragma config FCMEN = ON // Fail-Safe Clock Monitor Enabled bit (Fail-Safe Clock Monitor is enabled)
#define _XTAL_FREQ 8000000
#define LED PORTAbits.RA0
#define SDA PORTBbits.RB4
#define SCL PORTBbits.RB6
#define SADDR TRISBbits.TRISB4
char SEC,MIN,HOUR,DATE,MONTH,YEAR,DAY, SEC1;
int a,b,c,d,e,f,g,h;
char DAYS[8][4]={"SUN","MUN","TUE","WED","THU","FRI","SAT"};
char arr[7];
char time[8];
void START_I2C()
SDA=1;
SCL=1;
__delay_ms(20);
SDA=0;
__delay_ms(20);
SCL=0;
// LCD_POS(2,0x01);
// LCD_STRING("S");
void STOP_I2C()
SDA=0;
SCL=1;
SCL=1;
__delay_ms(20);
SDA=1;
// LCD_POS(1,0x08);
// LCD_STRING("p");
void WRITE_I2C_DATA(char d)
char i;
SCL=0;
SDA=0;
__delay_ms(20);
for(i=0;i<=7;i++)
if((d & 0x80) ==0x80)
SDA=1;
// LCD_POS(2,0x03);
//LCD_STRING("P");
else
SDA=0;
// LCD_POS(2,0x03);
// LCD_STRING("Q");
d=d<<1;
__delay_us(20);
SCL=1;
SCL=1;
__delay_us(20);
SCL=0;
__delay_us(20);
i=SDA;
// LCD_POS(2,0x05);
// LCD_STRING("S");
SCL=1;
__delay_us(20);
SCL=0;
__delay_us(20);
/* for(i=0;i<=7;i++)
SDA=((d&0x80)?1:0);
d=d<<1;
LCD_POS(2,0x05);
LCD_STRING("S");
__delay_us(20);
SCL=1;
SCL=1;
__delay_us(20);
SCL=0;
__delay_us(20);
i=SDA;
LCD_POS(1,0x03);
LCD_STRING("P");
SCL=1;
__delay_us(20);
SCL=0;
__delay_us(20);*/
void WRITE_I2C(char data,char caddr)
START_I2C();
WRITE_I2C_DATA(0xD0);
WRITE_I2C_DATA(data);
WRITE_I2C_DATA(caddr);
STOP_I2C();
void SET_CLOCK()
WRITE_I2C(0x00,0x00); //SEC
__delay_ms(2);
WRITE_I2C(0x01,0x58); //MIN
__delay_ms(2);
WRITE_I2C(0x02,0x16);//HOUR
__delay_ms(2);
WRITE_I2C(0x03,0x6);//DAY
__delay_ms(2);
WRITE_I2C(0x04,0x18);//DATE
__delay_ms(2);
WRITE_I2C(0x05,0x09);//MONTH
__delay_ms(2);
WRITE_I2C(0x06,0x15);//YEAR
__delay_ms(2);
char READ_I2C_DATA(void)
char i;
char j;
SADDR=1;
SCL=0;
j=0x00;
for(i=0;i<=7;i++)
// LCD_POS(2,0x01);
// LCD_STRING("s1");
j=j<<1;
// LCD_POS(2,0x01);
// LCD_DATA(j);
SCL=1;
j |=SDA;
SCL=0;
// LCD_POS(2,0x04);
// LCD_STRING("s2");
SADDR=0;
SDA=1;
SCL=1;
SCL=1;
SCL=0;
return j;
// LCD_POS(2,0x07);
// LCD_STRING("s3");
char READ_I2C(char daddr)
char s1;
START_I2C();
WRITE_I2C_DATA(0xD0);// write
//LCD_POS(2,0x07);
// LCD_STRING("S3");
WRITE_I2C_DATA(daddr);
// WRITE_I2C_DATA(0x07);
// WRITE_I2C_DATA(0x10);
START_I2C();
WRITE_I2C_DATA(0xD1);// read
s1= READ_I2C_DATA();
// LCD_POS(2,0x01);
// LCD_DATA(s1);
STOP_I2C();
return s1;
char CONVERT(int fdata)
fdata=(fdata>>4);
return fdata;
char CONVERT1(int gdata)
gdata=(gdata>>4);
return gdata;
int main(void)
long int s=0;
OSCCONbits.IRCF=0x7;
// char a=0x12;
ANSEL=0X00;
ANSELH=0X00;
TRISB=0x00;
TRISAbits.TRISA0=0x00;
TRISAbits.TRISA1=0x00;
TRISAbits.TRISA2=0x00;
TRISCbits.TRISC0=0x00;
TRISCbits.TRISC1=0x00;
TRISCbits.TRISC2=0x00;
TRISCbits.TRISC3=0x00;
// INTCONbits.INTF=0;
//__delay_us(20);
LCD_PRE_INIT();
__delay_us(200);
LCD_INIT();
__delay_us(10);
LCD_INIT();
__delay_us(10);
LCD_INIT();
__delay_us(10);
__delay_ms(200);
SET_CLOCK();
__delay_ms(10);
LCD_POS(1,0x01);
__delay_us(20);
LCD_CMD(0x80);
LCD_STRING("SAGAR");
LCD_CMD(0xE0);
while(1)
// s++;
SEC=READ_I2C(0x00);
// SEC1=CONVERT(SEC);
///SEC1=CONVERT1(SEC);
// LCD_POS(2,0x01);
// LCD_DATA(SEC);
MIN=READ_I2C(0x01);
// LCD_POS(2,0x03);
// LCD_DATA(MIN);
HOUR=READ_I2C(0x02);
// LCD_POS(2,0x05);
/// LCD_DATA(HOUR);
DAY=READ_I2C(0x03);
// LCD_POS(2,0x07);
// LCD_DATA(DAY);
/* DATE=READ_I2C(0x04);
MONTH=READ_I2C(0x05);
YEAR=READ_I2C(0x06);*/
LCD_CLEAR();
LCD_POS(1,0x01);
// LCD_DATA(a);
/* SEC=arr[0];
MIN=arr[1];
HOUR=arr[1];
time[6]=CONVERT(SEC);
time[7]=CONVERT1(SEC);
time[5]=':';
time[3]=CONVERT(MIN);
time[4]=CONVERT1(MIN);
time[2]=':';
time[1]=CONVERT(HOUR);
time[0]=CONVERT1(HOUR);
int i;
for(i=0;i<=7;i++)
LCD_DATA(time[i]);
// HOUR=0x05;
// LCD_DATA(HOUR);
LCD_DATA(HOUR/0x10+0x30);
LCD_DATA(HOUR%0x10+0x30);
// __delay_ms(1);
// LCD_DATA(MIN=0x10);
LCD_DATA(':');
LCD_DATA(MIN/0x10+0x30);
LCD_DATA(MIN%0x10+0x30);
// __delay_ms(1);
LCD_DATA(':');
LCD_DATA(SEC/0x10+0x30);
LCD_DATA(SEC%0x10+0x30);
LCD_DATA(' ');
LCD_DATA(' ');
// __delay_ms(1);
// LCD_STRING(DAY[DAYS-1]);
// __delay_ms(1);
/* LCD_POS(2,0x01);
LCD_DATA(DATE/0x10+0x30);
LCD_DATA(DATE%0x10+0x30);
// LCD_STRING('');
LCD_DATA(' ');
LCD_STRING("/");
LCD_DATA(' ');
// __delay_ms(1);
LCD_DATA(MONTH/0x10+0x30);
LCD_DATA(MONTH%0x10+0x30);
LCD_DATA(' ');
LCD_STRING("/");
LCD_DATA(' ');
// __delay_ms(1);
LCD_DATA(YEAR/0x10+0x30);
LCD_DATA(YEAR%0x10+0x30);*/
// __delay_ms(1);
/* if(s>=20)
s=0;
LCD_TIME(40);
LCD_CLEAR();
