pradeep.pavai
Newbie level 3
i have interfaced ds1307 with 89v51rd2.i am getting the output in uart,but it is wrong.i am getting as time=36:32:0D,Date=1F/1C/3F.can any one help me soon.i have to complete it....
here is the code...
here is the code...
#include "MF_RC500.h"
#include "MF_Func.h"
//com interrupt server route frandy
void serial_interrupt() interrupt 4 using 1
if(RI)
RI=0;
com_tmr_rx=5;
com_r_busy=1;
datas[0]=SBUF;
if(TI)
TI=0;
TX_RX=0;
if(com_t_index<com_t_length)
TX_RX=1;
//if(datas[com_t_index++])
//SBUF=hextoascii(((datas[com_t_index])>>4)&0x0F);
//SBUF=hextoascii((datas[com_t_index])&0x0F);
//com_t_index++;
SBUF=(datas[com_t_index++]);
else
com_t_index=com_t_length=0;
TX_RX=0;
//SBUF='\r';
void Sys_Init(void)
RC500CS = 0;
RC500RST=0;
IE=0x00;
PCON &= ~0x80;
SCON = 0x50; //mode 1,ren=1
TMOD=0x21; //timer 0 is 16 bit
TH1 = BAUD_9600;
TL1 = BAUD_9600;
TR1 = 1;
TH0 = TH0_20ms; //0x2800 time is 60ms
TL0 = TL0_20ms;
TR0 = 1; //timer 1 run
ET0 = 1;
ET1 = 0;
ES = 1;
EX0=1;
IT0 = 1;
size=0;
sec_num=block_num/4;
EA=1;
TX_RX=0;
//OPEN=0;
AUXR = 0x02;
void timer0_int(void) interrupt 1 using 2
TR0=0;
TH0=TH0_20ms;
TL0=TL0_20ms;
if(com_tmr_rx) com_tmr_rx--;
TR0=1;
void watch_dog()
WDG=~WDG;
void delay_10ms(uchar _10ms)
while (_10ms--)
WDG=!WDG;
delay_1ms(10);
void delay_20ms(uchar _20ms)
while (_20ms--)
WDG=!WDG;
delay_1ms(20);
void delay_50ms(uchar _50ms)
while (_50ms--)
WDG=!WDG;
delay_1ms(50);
void delay_100ms(uchar _100ms){
while (_100ms--)
WDG=!WDG;
delay_1ms(100);
void delay_50us(unsigned char _50us)
while(_50us--)
WDG=!WDG;
_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
void delay_1ms(uchar _1ms)
while (_1ms--)
WDG=!WDG;
delay_50us(25);
void main(void)
unsigned int sec, min, hour, date, month, year;
//uchar sec=0x00, min=0x00, hour=0x00, date=0x00, month=0x00, year=0x00;
// unsigned int i;
// RLED=1;
// GLED=1;
// WP=1;
// SPK=1;
// WDG = 0;
// WDG = 1;
//RC500CS=0;
Sys_Init();
//watch_dog();
DS1307_init();
// RLED=1;
DS1307_settime(0x01,0x01,0x01); /* Set Time (hh:mm:ss) */
// delay_10ms(10);
// DS1307_setdate(0x01,0x01,0x01); /* Set Date (dd/mm/yy) */
while (1)
//watch_dog();
GLED=0;
delay_10ms(10);
GLED=1;
/* Get Date & Time */
sec = (DS1307_get(SEC));
// delay_10ms(10);
min = (DS1307_get(MIN));
// delay_10ms(10);
hour = (DS1307_get(HOUR));
// delay_10ms(10);
date = (DS1307_get(DATE));
// delay_10ms(10);
month = (DS1307_get(MONTH));
// delay_10ms(10);
year = (DS1307_get(YEAR));
// delay_10ms(10);
// bcd2ascii(sec);
// bcd2ascii(min);
// bcd2ascii(hour);
// bcd2ascii(date);
// bcd2ascii(month);
// bcd2ascii(year);
datas[0] = hextoascii(((BCD2HEX(hour))>>4)&0x0F);
datas[1] = hextoascii((BCD2HEX(hour))&0x0f);
datas[2]=':';
datas[3]=hextoascii(((BCD2HEX(min))>>4)&0x0F);
datas[4]=hextoascii((BCD2HEX(min))&0x0f);
datas[5]=':';
datas[6]=hextoascii(((BCD2HEX(sec))>>4)&0x0F);
datas[7]=hextoascii((BCD2HEX(sec))&0x0f);
datas[8]=' ';
datas[9]=hextoascii(((BCD2HEX(date))>>4)&0x0F);
datas[10]=hextoascii((BCD2HEX(date))&0x0f);
datas[11]='/';
datas[12]=hextoascii(((BCD2HEX(month))>>4)&0x0F);
datas[13]=hextoascii((BCD2HEX(month))&0x0f);
datas[14]='/';
datas[15]=hextoascii(((BCD2HEX(year))>>4)&0x0F);
datas[16]=hextoascii((BCD2HEX(year))&0x0f);
datas[17]='\r';
com_t_index=0;
com_t_length=18;
TX_RX=1;
watch_dog();
TI=1;
/* datas[0]=hextoascii((sec>>4)&0x0F);
datas[1]=hextoascii((sec)&0x0F);
datas[2]=':';
datas[3]=hextoascii((min>>4)&0x0F);
datas[4]=hextoascii((min)&0x0F);
datas[5]=':';
datas[6]=hextoascii((hour>>4)&0x0F);
datas[7]=hextoascii((hour)&0x0F);
datas[8]=' ';
datas[9]=hextoascii((date>>4)&0x0F);
datas[10]=hextoascii((date)&0x0F);
datas[11]='/';
datas[12]=hextoascii((month>>4)&0x0F);
datas[13]=hextoascii((month)&0x0F);
datas[14]='/';
datas[15]=hextoascii((year>>4)&0x0F);
datas[16]=hextoascii((year)&0x0F);
datas[17]='\r';
com_t_index=0;
com_t_length=18;
TX_RX=1;
watch_dog();
TI=1;*/
delay_50ms(50);
void DS1307_init(void)
I2C_start();
I2C_write(DS1307_ID);
I2C_write(0x00);
I2C_write(0x00);
I2C_stop();
I2C_start();
I2C_write(0x07);
I2C_write(0x10);
I2C_stop();
unsigned int DS1307_get(unsigned char addr)
unsigned int ret=0;
I2C_write(DS1307_ID); /* Connect to DS1307 */
I2C_write(addr); /* Request RAM address on DS1307 */
I2C_start(); /* Start i2c bus */
I2C_write(DS1307_ID+1); /* Connect to DS1307 for Read */
ret = I2C_read(); /* Receive data */
/* datas[0]=hextoascii((ret>>4)&0x0F);
datas[1]=hextoascii((ret)&0x0F);
com_t_index=0;
com_t_length=2;
TX_RX=1;
watch_dog();
TI=1;*/
//delay_10ms(10);
I2C_stop(); /* Stop i2c bus */
return ((((ret>>4)&0x0F)*10)+(ret&0x0F));;
void DS1307_settime(unsigned char hh, unsigned char mm, unsigned char ss)
I2C_start();
I2C_write(DS1307_ID); /* connect to DS1307 */
I2C_write(0x00); /* Request RAM address at 00H */
I2C_write(ss); /* Write sec on RAM address 00H */
I2C_write(mm); /* Write min on RAM address 01H */
I2C_write(hh); /* Write hour on RAM address 02H */
//delay_20ms(20);
void DS1307_setdate(unsigned char dd, unsigned char mm, unsigned char yy)
I2C_start();
I2C_write(0x04); /* Request RAM address at 04H */
I2C_write(dd); /* Write date on RAM address 04H */
I2C_write(mm); /* Write month on RAM address 05H */
I2C_write(yy); /* Write year on RAM address 06H */
//delay_20ms(20);
void I2C_delay(void)
unsigned char i;
for(i=0; i<I2C_DELAY; i++);
void I2C_clock(void)
I2C_delay();
SCL_1 = 1; /* Start clock */
I2C_delay();
SCL_1 = 0; /* Clear SCL */
void I2C_start(void)
if(SCL_1)
SDA_1 = 1; /* Set SDA */
SCL_1 = 1; /* Set SCL */
I2C_delay();
SDA_1 = 0; /* Clear SDA */
I2C_delay();
void I2C_stop(void)
if(SCL_1)
I2C_delay();
I2C_delay();
bit I2C_write(unsigned char dat)
bit data_bit;
unsigned char i;
for(i=0;i<8;i++) /* For loop 8 time(send data 1 byte) */
data_bit = dat & 0x80; /* Filter MSB bit keep to data_bit */
SDA_1 = data_bit; /* Send data_bit to SDA */
I2C_clock(); /* Call for send data to i2c bus */
dat = dat<<1;
I2C_delay();
I2C_delay();
data_bit = SDA_1; /* Check acknowledge */
// I2C_ack();
/* datas[0]=hextoascii((data_bit));
com_t_index=0;
com_t_length=1;
TX_RX=1;
watch_dog();
TI=1;*/
I2C_delay();
return data_bit; /* If send_bit = 0 i2c is valid */
unsigned char I2C_read(void)
bit rd_bit;
unsigned char i;
unsigned int dat=0;
for(i=0;i<8;i++) /* For loop read data 1 byte */
I2C_delay();
I2C_delay();
rd_bit = SDA_1; /* Keep for check acknowledge */
dat = dat<<1;
dat = dat | rd_bit; /* Keep bit data in dat */
return dat;
/*void I2C_ack()
SDA_1 = 0; // Clear SDA
I2C_delay();
I2C_clock(); //Call for send data to i2c bus
SDA_1 = 1; // Set SDA
void I2C_noack()
I2C_delay();
I2C_clock(); // Call for send data to i2c bus
SCL_1 = 1; // Set SCL
unsigned short int hextoascii (unsigned char c)
unsigned char ch = c;
unsigned char as1;
unsigned char as2;
// take the char and turn it to ASCII
as1 = ch;
as1 >>= 4;
as1 &= 0x0F;
if ( as1<10 )
as1 += 48;
else
as1 += 55;
as2 = ch;
as2 &= 0x0F;
if ( as2<10 )
as2 += 48;
else
as2 += 55;
return( ((unsigned short int)(as1)<<8) + as2 );
unsigned char BCD2HEX(unsigned int bcd)
unsigned char temp;
temp=((bcd>>8)*100)|((bcd>>4)*10)|(bcd&0x0f);
return temp;
/*unsigned char BCD2UpperCh(unsigned char bcd)
return ((bcd >> 4) + '0');
unsigned char BCD2LowerCh(unsigned char bcd)
return ((bcd & 0x0F) + '0');
void bcd2ascii(unsigned int val)
unsigned int d1=0,d2=0;
d1= val & 0xf0;
d1=d1 >> 4;
d2=val & 0x0f;
d1=d1 | 0x30; //ascii values
d2=d2 | 0x30;//ascii values..
datas[0]=d1;
datas[1]=d2;
com_t_index=0;
com_t_length=2;
TX_RX=1;
watch_dog();
TI=1;
unsigned char asciitohex (unsigned char ch)
/* if( (ch < 0x3A) && (ch > 0x2F) )
return(ch - 0x30);
if( (ch < 0x47 ) && (ch > 0x40) )
return(ch - 0x37);
if( (ch < 0x67 ) && (ch > 0x60) )
return(ch - 0x57);
return(0xff);*/
if((ch>=48)&&(ch<=57))
return(ch-'0');
else
return(ch-'A'+10);
