Driving MOSFET in battery powered circuit
igru25
Hello all,
I have prepared following circuit and I have troubles with MOSFET driving.
Circuit info:
  • VDD = 2.8V (two fully charged NiMH AA batteries)
  • NE555N replaced by ST555CN (CMOS, from 2V power supply)
  • IRLZ44Z replaced by IRL3705N
  • Q2 MOSFET activated 1-2 times per minute for 0.1 second (duty = 0.2-0.4%).
The problem:
I have prepared breadboard test circuit and there is no enough voltage in batteries to fully open the MOSFET Q2 using totem-pole configuration. Solenoid M1 is too slow, Q2 is not fully open.
I tried four batteries and circuit worked as expected. But I must save weight and I cannot use four batteries. Two light 3V Lithium-ion cells - is an option, but too expensive.
I have two beginner questions:
  1. Can I utilize the booster output (15.8V) to drive Q2 MOSFET and how can I do it efficiently?
  2. Can I utilize the booster output to power CMOS 555 timer and how can I do it efficiently? I think if battery voltage drops below 2V - timer will not work.
I can imagine voltage divider - from booster output to supply totem-pole and timer - but it is not efficient. Am I right?
May be programmable voltage reference TL431 using booster output as input? Is it efficient way?
I need most efficient way to save battery power.
Please suggest.
Thank you in advance.
