bodzio_stawski
Newbie level 5
Hello
I have a question about driving LED in different, inverted way: the LED should light on when the signal/state is LOW and the same LED should be turned off when the signal is HIGH.
I have attached a schematic which this solution with two npn transistors to do it simply without specific IC's.
But I wonder what about efficiency. If we think about using ONLY transistors (bipolar or MOSFET, doesn't matters), is it the best way (I mean this circuit configuration strictly) to drive the LED with a reasonable low current drawn by the circuit? I ask because driving LED circuit in inverted way requires to be powered the whole time.
Regards, Bogdan
Regards, Bogdan
