engrMunna
I am drving a series RLC circuit (see picture) with a square wave which has the same fundamental frequency as that of the resonance frequency of the RLC circuit. I have place a 600 miliOhm (0.6 Ohm) resistance in front of the source (just for the sake of the simulation). Now across the 50 ohm resistor I get a sine wave, which I should as this is a bandpass filter.
But my question is about the waveform at the node in between the 0.6 Ohm resistance and L112 (48.7nH). Here according to my undersanding I shold have a square wave but what I get is a square wave with some curves at the top of it pulse...if you see the picture you'll get what I mean by curve.
In the wavefrom picture, the dotted line is the voltage at the node i mentioned, and you can see the curve in the voltage waveform as compared to the voltage of the source.
At the bottom is the sine wave i get across the 50 ohm resistance.
So why does the voltage waveform have a curve at the node in between R3 and L112?????
