dr pepper
Advanced Member level 1
I recently got a azimuth rotator instrument I want to drive, it has a differential synchro in it, 24vdc, both the stator and the rotor have 3 phase windings, usually this device indicates the diference between 2 3 phase signals.
I'm thinking if I feed the device 3 phases with 120degree shift between each which works with 3 wire dc 'syns, then wiring the rotor to the stator with 2 wires crossed to generate a 120 degree shift.
Will this work?
Will this work?
