Driver Development - how can i compile this source?
real_tr
Member level 3
Member level 3
Turkiye
Driver Development
Hi to all,
I want to create a driver for my application
I use ms vc .net but it gives error at ntddk.h
What dou you use to compile drivers?
Re: Driver Development
real_tr said:
Hi to all,
you should use the command line as you can see it at the start menu ->DDK(i forgot the whole name) after you install DDK, then
type "> build" in any example driver directory.
ps. using vs.net is ok but it requires further steps to setup the environment.
aramis
