driver circuit for my circuit
gosrivats
Newbie level 5
Newbie level 5
Chennai, Tamil Nadu, India
i m currently working on this circuit.in the attachment...i have a problem with driver circuit i m using IR2110 as i have two high side and two low side....first of all i have doubt whether i can use high side and low side driver for this as the pulses are of different...can u guys help me out please Untitled.jpgUntitled1.jpg
It looks like you have 1 low side switch and 3 high side (non grounded) switches. That will take 3 IR2110 chips.
IR2110 bootstrap supply can't work for S1 and S2 (presumed your driver supply and input signal is referred to VH-). You'll need at least a second floating driver supply voltage. There are additional questions, e.g. does the "mid" voltage node tolerate DC bias currents of the IR2110 driver?
