Drive Image and Server 2000
DrWhoF
Advanced Member level 1
I have a computer running WIN SERVER2000. I would like to make C-drive image and I have Drive Image 7.
Problem is that DI7 is not compatible with Server2000 and will not even install on this PC. Do I need an update for DI7 and will it work?
Tanks.
A lot of programs that need access to low-level API's do not run on WinServer2000. Keep in mind that Win2000 server is a different platform than Win2000 prof. Normally software makers supply different versions for wins server 2000. Norton Anti-virus is an example.
I suggest that you get a proper version of DI7.
Drive Image 7 runs only on Windows XP Home and Professional,
as well as Windows 2000 Professional Version .. all Desktops, but not servers.
Try to find:
V2i Protector Version 2.00 multiLangual
Type: Server Edition ISO
Regards..
IanP
This software is onlyavailable from SYMANTEC and there is now way I can download it from them for free.
What are other options or someone knows how to get this software?
Thanks.
one simple soln, install windows XP on a small harddisk, install drive image on it and then make the image of your server HHD.
should work as i use it for backup of even linux partition.
hock
