Drill Size & Stop Mask errors
vinodquilon
Full Member level 3
Full Member level 3
What is the meaning of Drill Size & Stop Mask errors in Cadsoft Eagle PCB layout ?
How can I fix it ?
When are you getting the errors? When you create the Gerber files? What CAM job did you load?
Keith
wire width
How can I change all the wire width on pcb layout at a time, without going to properties each wire ?
ofjavascript:emoticon(':cry:')
Select the whole PCB as a block. Type 'change width 0.5' for example to change all widths to 0,5mm. 'cha wid 0.5' would work as well - most commands can be abbreviated.
The commands are shortcuts to the menus. The alternative is to select the change icon on the left hand icons - a spanner I think!
Keith
