Drill Drawing Printout using design view in Altium 14
carlosc
Newbie level 2
Newbie level 2
I am trying to print the drill drawing layer using "place design view". I can see the symbols for all the hole sizes I am using when I place the design view object on the pcb. However, when I try printing using an outjob, the symbols do not print. Even whe I select the drill drawing to be printed. Help would be greatly appreciated. I am using Altium 14.1.5. thanks.
I am familiar with Proteus Ares,with it I can help you!!
Not very clearly understand your question.But if you want to see the sympols of the holes,I have a method.
1、place legend on topoverlay, Place-----String------Left Click to put the string anywhere you want.---------Then double Click to change the attribute just as the left picture showed.-----Then you need to export Gerber ,be carefull the setup when you export Gerber,just as picture showed right.
Hope it can help you.
