nitin.maurya1
Junior Member level 2
- Joined
- Nov 12, 2011
- Messages
- 22
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Varanasi, India
- Activity points
- 1,438
Hi Nitin,
Higher the Electric Field ,means carrier will be swept faster,but the current depends on no of carriers and not their velocity ,
whether it is hole or electron their number determines the current ,higher field implies the carriers will be swept faster .
Electrical current is a measure of the amount of electrical charge transferred per unit time. It represents the flow of electrons through a conductive material. The SI unit of electrical current is the ampere, defined as 1 coulomb/second. So higher the velocity you will have more charge flowing per unit time. Check the drift current in equation it is directly proportional to applied electric field.
Drift current - Wikipedia, the free encyclopedia
When applied electric field is strong enough, the carrier velocity in the semiconductor reaches a maximum value, saturation velocity. When this happens, the semiconductor is said to be in a state of velocity saturation. As the applied electric field increases from that point, the carrier velocity no longer increases because the carriers lose energy through increased levels of interaction with the lattice, by emitting phonons and even photons as soon as the carrier energy is large enough to do so.
Velocity saturation - Wikipedia, the free encyclopedia
But the no of carriers of is important ,field determines the velocitySo higher the velocity you will have more charge flowing per unit time
drift current is due to generation and recombination of carriers
As I read your references, I got the following idea;
" Drift current is generated by minority carriers in PN junction, and this is equal to diffusion current but flows in opposite direction. Since biasing and hence Electric field only generates Majority carriers, Drift is independent of biasing."
But as minority charge carriers can be thermally generated, drift current is temperature dependent.
Am I correct?
Drift current is independent of applied bias
Drift current only in the case of PN junction is independent of applied bias. Because drift current in PN junction is due the minority carriers. Minority carriers are generated by temperature so drift current is temperature dependent. When the diode is forward biased drift current is present, but because diffusion current grows exponentially, it dominates. The total current flowing through the depletion region under forward biasing is made up of mostly majority carrier diffusion. But this is not true in case of the MOSFET. Drift current in MOSFET is due to majority carriers. In case of MOSFET drift current increase with applied electric field till the Velocity saturation.
