[SOLVED] DRC Error in Proteus ARES
Leplouc
Newbie level 1
Newbie level 1
Hello,
Placing an SMD component (SQFP48 or similar multipin squared component) in Ares, shows a lot of DRC errors.
If I check the Design Rule Errors, the Specified Clearance value is 0th and the Actual Clearance Value is negative (-2.22, -3.13th....)
Reseting the Default Values makes no more change.
I am stucked to this point.
Some help welcome.
Gérard
