DRAW VIA HOLE, how to draw via in hfss.plz
alan6449
Full Member level 1
DRAW VIA HOLE
can anybody guide me how to draw via in hfss.plz..... i need urgent
regard
alan
Re: DRAW VIA HOLE
Hi Alan,
in order to draw a via hole in HFSS you just need to draw a cylinder having the desired radius between two conductors on different layers (for example, between the ground plane and the signal layer of a microstrip).
Via holes have a metallization on the inner surface of the cylinder. So, the volume inside must be subtracted from the dielectric substrated crossed by the via itself.
So, summarizing:
1) Draw the cylinder;
2) Subtract the cylinder from the dielectric substrate;
3) Select the cylindrical face in the subtracted region;
4) Apply PEC boundary or Finite Conductivity boundary (so as you can define material ,thickness, roughness, etc.);
Since via holes introduce a parasitic reactance and generally they are not perfect short circuits, thickness of metallization and cylinder radius become fundamental parameters in via holes' design. I advise to run a parametric analysis varying radius and thickness in order to reduce parasitic reactance.
Hope this helps.
