katrin
Full Member level 1
I have one question about guard ring.
I can either draw the guard ring by hand or add the guard ring automaticly for each side from transistors' properity.
When I draw the guard ring by hand, just add each layer manually, it is more time-consuming, but it is more flexible. I can leave some small opens for wiring.
The problem with automatic guard ring is that there is no open around the transistors for wiring. So I can only use one or two sides automatic guard ring.
I am wondering usually do people draw the guard ring manually or do you just use the automatic guard ring?
thanks
thanks
