dpsk .wav file in matlab
jess17
Junior Member level 3
ok, i need to modulate this .wav file in matlab. I tried the command
%to read .wav
[y,fs,n]=wavread('wavefile');
t = (1:n) / fs;
sound(y); %plays the sound and plots it.
figure(1)
plot(y)
%carrier signal.
% frequency
fc = fs/3;
c = cos(2 * pi * fc * t);
figure(2)
plot(t,c);
to modulate,
M=4;
sig =dpskmod(x,M)
i get an error saying "Error using ==> dpskmod at 41
Elements of input X must be integers in the range [0, M-1]."
what should the value of M be?
to modulate,
M=4;
sig =dpskmod(x,M)
First of all you did not specify x. It should be quantized value of the signal y. You must first quantize y with n bits resolution and then form symbols with values 0,1,2 or 3 using consecutive 2 bits of quantized signal (for M=4) . Store the resulting symbols in x and then execute
sig =dpskmod(x,M)
i tried with
M = 4; % Use DQPSK in this example, so M is 4.
Fs = 100;
t = [0:2*Fs+1]'/Fs;
Fc = 10; % Carrier frequency
x = sin(2*pi*t); % Sinusoidal signal
but keep getting the same error. Is quantising like converting it to digital form?
