kickbeer
Full Member level 3
i have just read some article about analog-to-digital converter. i'm confused with the range of analog input signal for example 1.4Vpp. does it mean from -0.7 V to + 0.7 V peak to peak?
RFDE said:if you use a differential architecture , then it means from -0.7 to 0.7 , i.e. Vref+=0.7 & Vref-=-0.7
amriths04 said:It just means that the input voltage range is 1.4V. The absolute minimum and maximum values depend on the input common-mode voltage about which your circuit is biased.
For example if in a single-ended (or differential) configuration, having a single power supply, if you have a input common mode of say, 0.9V, then, your input signal will swing from 0.9-0.7V to 0.9+0.7V.
If it is mentioned as differential peak-to-peak, your signal will swing from 0.9-0.35V to 0.9+0.35V in one of the differential inputs and would be antiphase in the other differential input.
Hope this helps.
amriths04 said:Yes, a common-mode voltage is a DC voltage that is used to bias a transistor, so that it operates in saturation. So the same common mode voltage appears at both the inputs. Your signal would be riding on it.
