doubt regarding resistance value in relay connection
bobdxcool
Member level 5
Member level 5
i am connecting p 1.2 of 8051 to a relay using a transistor setup as shown in figure below!
what value of resistance should i use between pin 1.2 and base of transistor..i am using bc 547!
and the relay specs are
7a/240 v ac
7a/24v dc
coil 12v dc
Generally, RB is calculated by:
RB = (Vcc x hFE) ÷ (5 x IL)
where:
Vcc is the IC's power supply (5V)
hFE is the transistor's gain (check your exact transistor(A,B,C) and datasheet, but let's say 120)
IL is the load current - see below.
You've missed out a critical parameter - the relay coil's resistance. With that, we can calculate the load current (I = V / R) then use the above to get the resistor value.
P.s. Don't cross post your questions to other forums.
where:
Vcc is the transistor's power supply (12V)
but i am connecting pin 1.2 of 8051 to transistor base...so should'nt we take 5 volts of 8051 instead of 12 volt??
and in load current calculation I = V / R....is V the rating (24 v dc or 240 ac) of relay or the 12 volts vcc applied??
lol -yes - the Vcc is the IC's supply. Just testing!
The load current involves the voltage you give to the coil - so it's 12 V. The relay's switch rating has nothing to do with it.
