Doubt regarding Operators
The & operator works with bits and the && operator works with states like boolean.
x = 0x05 & 0xff; /* working with bits */
if(switch_on && fuse_alight){ /* working with boolean */
run_like_f;
& helps you did bitwise operation, i.e. is actually performing the boolean arithmetic with individual 0's & 1's of two unsigned quantities. The result of it's operation is thus a numeric quantity (treated as unsigned, but C as a language allows you to break that).
&& is a logical operator, which operates on quantities that have logical-meaning of true/false, and the result of it's operation is also either true/false (not a numeric quantity)
In an application standpoint.
& is used for performing bitwise operation, such as if you want something like:
result = 0xFF & 0x00; //result = 0
but && operator is used for doing comparison such as:
if( (result > 0x01) && (result < 0x04)) ...
