Doubt in the rotation asm pic16F
aless2056
Member level 1
Member level 1
Guys, I'm a beginner and I'm in doubt in the RRF Rotation instruction. Assuming I have this value
0000 0011 0011 1100
AH = 0000 0011
AL = 0011 1100
Did I do that?
RRF AH, F
RRF AL, F
RRF AH, F
RRF AL, F
Will the result be?
AH = 0000 0000
AL = 1100 1111
The answer is: it depends.
I don't want to do your homework.
So please show the states after each commend. Step by step.
Klaus
You should study the data sheet, it explains all the instructions and gives examples.
'AH' and 'AL' presumably are register names and independent 8-bit values.
RRF AH, F AH is 0000 0011 before the instruction so rotating it right through the carry flag, bit 7 = whatever was in C, and C becomes what was in Bit 0
The same applies to the AL register but note there is only one carry bit so it may transfer a bit from one register to the next.
We can't predict what the result will be without knowing what was in C at the outset.
Brian.
