marsgod
Member level 4
if you set the LD_ASSUME_KERNEL=2.2.4 in your env, this will cause the latest DC crash when you try to compile big design. And also will cause Psyn crash when you try to use multiply processor to acclerate your speed.
Just remove the LD_ASSUME_KERNEL from your env, it will be ok.
good luck
good luck
