Doing the colour sensing using DIP part
aadarsh
Newbie level 6
Newbie level 6
india
Hiiiiii everyone,
i m ec 4 year student i need urgent help on one of the topic that i m thinking of actually i want to design a hardware that changes colour according to the environment and i m not sure whether it is possible to do the colour sensing part using dip , if yes kindly help me on that because i m not having knowledge of the dip part
Re: Defence future plans
Maybe you can try light dependent resistors' output fed to the microcontroller. If it's sunny outside you can make the color Yellow, If it's night then turn the color into blue. The voltage output will determine the range of the light and make some range also for the basis on the microcontroller. If you're using PIC microcontroller, you can use the ADC module. That is a nice project. Cheers :)
hi
you are going to change the colour of what? led lighting?
ml
thanks a lot for ur appreciation if u dont mind can u give a little bit more details of what u told about using LDR u can message me here on edaboard
---------- Post added at 22:17 ---------- Previous post was at 22:12 ----------
@microlab actually sir i m thinking of designing a hardware tht will change color lyk wht i was thinking is tht hardware will be having sheets of different colors over each other and will slide over each other to change color according to the environment and i need to detect color of environment from appreciable distance may be using DIP or anything else
---------- Post added at 22:19 ---------- Previous post was at 22:17 ----------
