Doing FFT in cadence analog environment
gogomi
Newbie level 6
Newbie level 6
cadence dft
Does someone know how to use FFT to transform the transient waveform into frequency domain in
cadence analog simulation environment? and is there any way to calculate the amplitude of one
time domain waveform? I coudn't find a good reference for the analog simulation environment.
Thank you very much for your help!
gogomickey
cadence fft
use dft function in calculator
    gogomi
    V
fft cadence
does the wave be in AC?
dft cadence
transient analysis first
dft in cadence
Transient analysis first you see waveform then:
There is a push-button in the toolbar with words: FFT, look it up...
and the second method is:
    gogomi
fft in cadence
just use calculator, click vt and choose the node you want to take fft. Then choose dft in calculator and choose the appropriate time interval and finally plot it
    gogomi
cadence calculator dft
choose a proper window is very important
how to dft in cadence
Yes, I finally got it. The setup is kind of tricky. I'll have to run a long transient time to get the frequency window. Thank you guys!
gogomickey
plotting fft in a cadence
A question about dft:
Does Cadence support different kind of windows?
Thx
how to do dft in cadence
Thx
Yes, there are about a dozen of windows you can choose.
cadence calculator fft
u can use digital proccessing method
