doesn't hsim have a graphical interface ?
wildwood
Junior Member level 2
i installed hsim4linux .
but when i type in the command hsim , i can't get a graphical interface , only a list of different parameters .
This is right. I use hsim for unix on workstation.
Hsim have not a graphical interface, I use debussy for watching waveform
You may use SpiceExploer or CosmoScope to view the waveform in Linux.
Nassda used to bondle OEM waveform viewer of nWave from Springsoft before.
is debussy the only tool to view .out wavefile?
if not which can i select?
