Does VB have special character that represent enter char?
cwt
Member level 5
Member level 5
Next line character
Hi out there..
Does VB have any special character that represent the 'enter' event?
In some other programming lauguage, '\n' symbol is use to represent the enter (next line character). So do VB have any of that? :?
Thanks!
:eek:
Next line character
THanks..
But i cant see the effect..except a "|" symbol like that?
What i need is..the following sentence will appear at the next line.
Re: Next line character
chr$(13) is the ASCII code for Carriage Return. The ASCII is the standard notation for characters. VB understands ASCII, and I would say that \n is the alternative to CHR$(13) than otherwise.
Anyway, if it doesn't work, it would be due to other factors. Could it be that you are trying to write into a single-line textbox?
Usually I use the VbCrLf which corresponds to the chr$(13) e chr$(10) [Carriage return ans Line Feed].
Ex. Text1.text=Text1.text & "what you want to print" & VbCrLf
You can find more info on MSDN at the topic "String Constants"
bye wn.
Next line character
To: checkmate, i am using multiline..
THanks anyway!!
VbCrLf definately is the effect that i needed..
Thank you so much..
I'm not good at VB, but I'm accomplished in assemble language. I know that Chr$(13) only means the Carriage Return(CR), but the '\n' means a line feed and a CR. So you should use both Chr$(10) and Chr$(13).
Not always, it depends on what RS232 receiver you use :? many only need chr(13)
