SparkyChem
Member level 3
- Joined
- Apr 22, 2010
- Messages
- 57
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Lima, Peru
- Activity points
- 2,084
Howdy!. I'm intending to find a replacement cable for my cablemodem unit. The existing cable that the phone company installed is a screw in terminal on both ends of the coaxial cable with one end connected to the modem and the other connected to a splitter.
What I intend to do is to replace the cable with another one which has a non screw F terminal, something which can be plugged by only pressing it against the female terminal either the modem or the splitter.
Upon browsing online I found these and also this.
The reason for why I intend to use these instead of the regular screw in type F connector is because my cablemodem is in a temporary place (as I have recently moved) and I have to disconnect it from time to time to take the unit to other part of the house.
And I noticed after unplugging it a couple of times the screw indents on the edges of the female and male terminals seem to be wearing off. In order to avoid further worsening the situation (other than obviously finding for them a more permanent place, which I cannot do for the time being) I considered to use these friendly pushing in alternatives for a type F connector.
However, neither of these indicate if the signal will be affected by using this?. Will it make any noticeable difference?. Back in the 90s my tv cable provider installed the cable to a wall in my house and I noticed the socket in the wall had much noise, so when I replaced the F terminal and connected it directly to the tv it improved a lot the quality of the image, hence my question.
I do not have an oscilloscope neither any other sophisticated equipment to verify this. But does it exist any reason to believe such?
Has anyone used these cables?. I remember using them on my VCR equipment back in the 90s as well and I had good experience using these push only F terminals, never had any sort of diminishing the quality. But since I intend to use these for a cablemodem which transfers data, will that make any difference?. If I buy the cable on amazon which I had referenced earlier will it be a safe choice?. Does the influx of information on a coaxial cable will it make it get hot or something? Does it exist better alternatives along the options which I have mentioned above?.
AS mentioned I also found this but I have no idea if it will be safe, does it exist some specification or some group of cables which say specifically only for tv use or not for internet use. Does it exist some standard for this? Can someone guide me with this matter?. So far I do remember that RG59 coax cable has a higher impedance than RG6 and typically lower impedance cables are used for data while higher are used on tv or video signals, but would it mean that in terms of power dissipation, one may heat more or something like that?.
