elec-eng
Full Member level 5
synchronizer same clock
Hi all
Could you please help me
I have a design at which multiple synchronous clocks are used "as depicted in the picture"
So I have the case of "Synchronous Clock Dominn Crossing" , i.e the clocks have the following properties:
-They are derived clocks " i.e they are from the same root clock"
-Each clock is an integer multiple of the root clock
-All positive-going edges of all clocks are alligned
So, Does I have to use synchronizers "2 Flip-Flops or FIFO" between different
sunsystems using these synchronous clocks
thanks
Hi all
thanks
