skatefast08
Full Member level 4
Wouldn't the wave equation apply to only waves at low frequency?
I read in this article: https://www.animations.physics.unsw.edu.au/jw/wave_equation_speed.htm, that the equation for a wave that was analyzed as a PDE, had to be a wave with only small deformation, meaning that it would have to be a wave that has only low frequency, correct? because, if the wave had a very high frequency, the same wave equation in the article wouldn't conform, because some of the angles from an infinitley small portion of that wave would be too large and hence the wave equation wouldn't work, right? I hope you understand my question. I just wanted to understand this in a more intuitive way. Thanks.
