Does s1 violation has to be resolved at dftadvisor or fastscan?
gold_2007
Member level 1
Member level 1
bangalore
can anyone tell me whether s1 violation has to be resolved at dftadvisor or fastscan ?
Re: dft (S1)
S1 needs to be analyyzed in dftadvisore . Use report dft check to find out the gate where this failure occurs then you can add this gate in DFT visualizer else in DFTADVISOR DFT mode you can have
analze drc ciol s1-2 ( assuming it is the 2nd S1 violation )
rep drc rule s1-2
    gold_2007
Re: dft (S1)
for S1 violation when i give "insert test logic -scan on -test on" command then i dont see the S1 violation in dftadvisor control panal . does that mean S1 violation doesnt exit any more
dft (S1)
Yes , i think you have deal with the question.
Re: dft (S1)
the scanned netlist again when i use in dftadvisor i get again S1 violation. So that means i ve not resolved the violations.
dft (S1)
Sometimes , it is just a warning not the error.
And i remember S1 just use "insert test logic -scan on -test on" to deal with and sometimes you should set the test logic cell. And you can check you training book.
    gold_2007
Re: dft (S1)
You have instructed the tool to add test logic to resolve S1. In the scan inserted netlist also test logic will be inserted. If you don't constrain the test_en(Test pin), you will again get the S1. Constrain it & run the DFTA in scan inserted netlist.
    gold_2007
