Does keil wok on assambly for 89c51
Noman Yousaf
Full Member level 4
Full Member level 4
Lahore Pakistan
I want to know that i know only assambly of 89C51. I do'nt know C
i have keil software. I intalled that.I found all the thing related to "C" i couldn't gat any thing related to assambly there.
But on CD (supplied with), assambler, debuger is written.
Can any body make it clear. And tell me that how I can work on keil with Assambly
Thanks in adv
Does ke*il wok on assambly for 89c51
HI,
with
These directives
#pragma ASM
---your asm code here------
#pragma ENDASM
Look for the C51.PDF file in hlp folder for more info.
Bye
If you know assembler, then program in assembler.
Look for the A51.PDF file in hlp folder. Chapter 3 is
"Writing Assembly Programs"
Bye
YES ... you can write assembly .. and only assembly on keil .. but I advice you not to .. try to learn C .. C is much more efficient .. and what u can do in assembly in 10 days , u can do better than it in C in 1 or 2 days ..
do you have @51.exe in ke!l? just check it.
@51.exe is for @ssembler.
