Does Hspice work with window's VISTA?
amiralib
Member level 4
Member level 4
Ian - Tabriz
Hi
I cant use the Hspice 2007.03 with windows Vista!
what can I do? any one have the same problem?
regards
vista hspice
Try to install them using the XP compatibility mode. I had problems with many other tools (Orcad, Protel etc) not compatible with VISTA, and after install them with the specific mode they now operate properly.
hspice for vista
How can I install them using the XP compatibility mode ?
can you explain more?
hspice 2007,vista
thanks
I installed this on WINXP mode ....
Hspiceu Z worked....but the Avanwaves didnt.....
has it another solution?
hspice installation on vista
hspice 2007.09 does, it appears.
Synopsys does not (yet) explicitly supports Vista, see
hspice installation vista
I guess some other programs can draw the hspice simulation rusults ! is it possible?
vista awaves
Try this: open up the HSPICE_version/BIN folder, right-click on hspui.exe and choose Properties. In the Compatibility tab, under Privilege Level, click the "Run this program as an administrator" check box.
Repeat the process for awaves.exe.
After I did this, it worked for me. (Of course, I have to say "Allow" to the "An unidentified program wants to access your computer" security message whenever I start up hspui.exe.)
hspice install vista
I need to calculate what is the limit of meshing density Vs memory RAM?
synopsis hspice vista issues
hello all
i do something to install hspice under vista and it worked
1st- install Hspice on vista
2nd- Change the environmetal variables
3rd- install hspice on another PC worked under XP environment
4th- copy the bin directory from XP machine and Paste it in Vista
5th- it work
try this and tell me
install hspice 2007 in win vista
It seems that this issue is related to the new UAC feature of Vista.
hspiceva window vista
hi hesham_gaber, it worked!!! great!!!
Does Hspice work with VISTA?
hello everyone...i also need help!!
i just install hspice ver:A-2008.03
i install that on laptop with vista os ..the hspui work but the avanwaves not..
i dont know how to make it work!!
Re: Does Hspice work with VISTA?
The method that hesham_gaber described works also for Windows 7 :-D. Tried that with hspice 2007.03 . No need for compatibilty mode. Just copy the bin folder from another computer with windows XP and paste it on the Windows 7 one. Also, create the required user variables.
Thanks !
