High Q causes a narrow bandwidth. At a higher frequency then you can have a wider modulation bandwidth.
Look in Google for the definition of the Q of an LC circuit. A high Q gives greater selectivity so the circuit selects only a few frequencies but rejects all other frequencies. A low Q circuit has poor selectivity so it selects many frequencies.
The statement is correct but the graph is wrong. The curve with high Q will have narrow tails and the graph with low Q will have fat tails.
Graph is correct the only difference is normalization. As BW is defined as Half Power so Higher Q graph has smaller BW as compared to Lower Q graph. Please correct me If I am wrong
Ok is this correct illustration of Q and BW?
When we talk of coupling then there comes yet another Q which is labelled as Q external. Rather coupling is defined by ratio of Q and Q external. So what is this Q external?The loading need to be counted as loss or dissipation. Tight coupling makes for low Q systems.
